My wireless internet connection has been pretty bad lately, so i finally decided to switch to wired. The only reason to why i havent done it earlier is because i live on the first floor and the router is on the second, so i need a very long cable pluss i need to drill a lot of holes to wire the cable to my room.
Before buying a cable i wanted to test how much faster my internet would be with a cable, I moved the PC upstairs beside the router and connected it to the router with a short cable that i had from before. Usually, my wireless connection is about 1.8mbps (i know, its slow. We are changing our internet provider soon). I connected the PC to the router with an ethernet cable and the connection remained the same, but this time it is at least stable.
One post suggested that I should deactive and then activate the ethernet network, but it didnt change anything. Anyone knows a solution to this problem?
