Wired desktop and wireless router Question.
G
Guest
Guest
Archived from groups: alt.internet.wireless (More info?)
I have a wireless setup for my laptop(XP_Home) and I wanted to add my
wired desktop(98SE) to the network as I don't have a wireless PC card.
The problem is my desktop doesnot have a CAT5 input only phone line. I
was until now connecting to my cable modem using USB port but now the
wireless router only has the CAT5 so I am not able to add my desktop
to is using USB.
I tried to connect my desktop directly to the Cable modem but a I am
not able to connect to Internet.
Please help. Do I need to buy additional hardware to connect my
desktop to the wireless router ???
Thanks a lot.
G
Guest
Guest
ritskits@yahoo.com (surbhi) wrote in message news:<91238b26.0409141926.79401b9b@posting.google.com>...
> to is using USB.
network cards a very inexpensive 8 - 15 bucks. since you're using 98
try to get the drivers from the place you bought, but they are easy
enough to download if you get a known brand like 3com etc. if you've
never installed anything in a PC before then you might want to have
somw help.
G
Guest
Guest
Do a search for usb to ethernet.. I have (4) on my pc right now....
>to is using USB.
>Thanks a lot.
DS
77
njkat@eclipse.net (gene martinez) wrote in news:41485071.22847671
@news.eclipse.net:
<SNIP>
DON'T do a search for USB to Ethernet. Why would you do that when a NIC can
be had for $5-$10 w/rebates or just plain on sale.
I never understood why USB is used for so many things. USB mouse, USB
keyboard, USB printer, USB to Eth. IMO, USB should be used for devices that
you plug and unplug regularly, i.e. a digital camera. That was the original
intention of USB from what I remember. I have a USB mouse, that came with a
PS2 adapter, so I use the PS2 port.
If you open up the device mangler, then view -> resources by type, and
expand IRQ, chances are ALL USB UsbHostController's share the same IRQ, and
MAY not be able to be changed. In my eye's, this is just a disaster waiting
to happen. It may be OK for very low usage devices, but even then I'd go a
different route if possible.
Oh yeah, a scanner is the only other USB device I'd probably use, since the
transfer rate is much better than the parallel port.
Regards,
DS
G
Guest
Guest
Yes, you need a Network Card. It's probably easier to get your local shop to
install it.
"surbhi" <ritskits@yahoo.com> wrote in message
news:91238b26.0409141926.79401b9b@posting.google.com...
> to is using USB.
> Thanks a lot.
G
Guest
Guest
Because the back side of a PC is a dreadful place to put a radio antenna.
The USB-wireless adapter can be mounted someplace with a better radio view
of the world. My DLink DWL-122, with a five foot cable, was $9.
I don't think "universal serial bus" has any particular "pluggable only"
connotation to it. Hotplug is part of the design, but that's true for a
lot of PCI cards as well.
> It may be OK for very low usage devices, but even then I'd go a different
> route if possible.
40-60MBpS disk drives are available for USB.
Aha! You've seen the light. ;-)
Size is king. The parallel port and serial ports are disappearing, both
from lack of use, and a need for space. One USB port with an external hub
can accomodate a lot of external devices that not everyone has. No need to
waste the space for ports that don't get used by 90% of the population.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
DS
77
dold@XReXXWired.usenet.us.com wrote in news:cialj0$s00$1@blue.rahul.net:
>> NIC can be had for $5-$10 w/rebates or just plain on sale.
> antenna. The USB-wireless adapter can be mounted someplace with a
> better radio view of the world. My DLink DWL-122, with a five foot
> cable, was $9.
I took the post as they wanted to add a wired connection, which is what
the OP said he/she wanted to do, and asked about hardware.
Also no need to use a wireless card on a desktop if it's within a wire's
shot of the switch, which undoubtably has a much lower potential for
issue's in the future, more secure, and with better performance.
> both from lack of use, and a need for space. One USB port with an
> external hub can accomodate a lot of external devices that not
> everyone has. No need to waste the space for ports that don't get
Just as a clarification, I agree with you, why not get rid of the stuff
that 90% of the people don't use. The serial port is very common in the
communications field, which I'm in, and most devices I use regularly have
regular old fashion com ports. I'm not completely against using it, but I
feel the implementation of it is flawed. One USB port to a 4-port USB hub
is still just one USB port. All of the devices connected to it are
fighting for it's piece of the bandwidth back thru the main line. There
is the real potential for problems with this setup when two or more of
these are high-thruput devices.
Thing's like a mouse and KB are trivial, and then you add a USB NIC, a
USB hard drive, scanner and printer, maybe even a video capture device,
the cable/DSL modem.....there's going to be some issue(s) somewhere.
There's 3,4,5, proprietary USB device driver's, all from different
manufacturers, interacting with one USB controller, and all of them are
sharing one hardware interupt. The PCI bus allows sharing IRQ's, but
there are known issue's with this, especially among video cards.
That's all....
Thanks for reading,
DS
G
Guest
Guest
>> cable, was $9.
Right you are... A $9 wired NIC is the way to go. I misread something.
Yep.
Lots of whining in the GPS group about the number of laptops that no longer
have serial ports, and in my way of thinking, they are more likely to need
them than desktops, but that may just be my usage pattern.
Similar threads
