[SOLVED] Wired Slow - 2mb on 1gb line - 300 mb running wireless
Sep 18, 2019
5
SOLVED - Updated Intel Ethernet Connection (2) I218-V (I could of swore I had already done that) and boom - wired internet if flying.
1st post here so if I leave anything out feel free to yell at me. I am about to go crazy!
I have ATT Gigafiber installed - New rollout and hookup.
PC hard wired with new Cat 6 cable into ATT modem/router combo: 2-4 mbs
PC hooked up to ATT Modem/Router Wireless: 300 mbs
PC Wireless Router Nighthawk AC2600: 200 mbs down
Wife work laptop (older windows laptop) wired into modem: 550 mbs down and 900+mbs up !!!! This is the only reason I know it isn't the modem.
I have run every scan known to man: Antivirus, Malwarebytes Pro, rkill
ATT Modem/Router combo: Arris
PC system info:
OS Name Microsoft Windows 10 Pro
Version 10.0.17763 Build 17763
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-3TV4PR9
System Manufacturer ASUS
System Model All Series
System Type x64-based PC
System SKU All
Processor Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 2801, 11/11/2015
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product Z97-A-USB31
BaseBoard Version Rev 1.xx
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "10.0.17763.737"
User Name DESKTOP-3TV4PR9\PCUser
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 5.40 GB
Total Virtual Memory 29.9 GB
Available Virtual Memory 15.4 GB
Page File Space 14.0 GB
Page File D:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Can anyone point me in the right direction?
I am fine with the 200 wireless running off the Nighthawk for everything in the house.
I just need to get the PC running at 500+ mbs hard wired in (10 feet away)
Thanks for any suggestions!
It may not help but assuming you have a built in ethernet adapter, have you tried uninstalling it in device manager, rescanning to get the PC to re-find the adapter, and then reinstalling / updating the drivers? I'm also on Windows 10 pro and have found the last couple of MS updates have totally knackered my ethernet connection to a point where it just crawls no matter what I do.
I've ended up having to use a 5g USB dongle on my desktop which is fine as I have a superfast router and broadband - but I'd rather use the internal hardware which is why I'm planning on migrating to Fedora Linux as I'm totally hacked off with Windows.
Do you have Killer brand network hardware or the Asus ROG game optimizer installed? Both of those software products will kill sequential network speed to improve game ping times.
Nope - just a 2016 pc build out from Feline PC with the specs listed in the post.
I don't understand why the wireless is 300+ when the wired is around 2-6 download. Then wifes old work computer can straight fly all wired in.
Im going to boot up from a live linux usb to test out whether it is some sort of Windows/sercurty/bloatware issue. Then the ethernet adaptor is next on my list.
THANKS
