Wireless-AC 7265 vs Advanced-N 6205
Christopher Ortiz
12
Alright guys i'm having an issue with the wireless in the new laptop I just purchased. It's a Toshiba Satellite Radius.
Question - If the wireless router does not have wireless-ac, does it make a performance difference with a device that has wireless-n?
Here's why im running speedtest.net on this new laptop and im getting speeds slower than my older Lenovo L520. Why is my older laptop with Advanced-N getting way faster speeds than my new laptop this is really bothering me.
The Advanced-N 6205 is a 2x2 MIMO device.
I can't find info on the AC 765; do you mean 7265? That's a 2x2 device, so should perform the same as the 6205 on an 802.11n AP.
Equivalent AC & N adapters should perform similarly when connected to an 802.11n AP.
Are you doing the speedtests from the same location and at a similar time of day? Can you post the results?
Sometimes antenna design can make a difference; you often get better speeds with the laptop facing one way rather than another.
Damn I messed up accidentally pressed that you posted the solution lol ill get some pictures of the speedtest for you. I was choosing the same server at the same time I mean a few seconds apart.
This is from the Wireless-AC
This is from Advanced-N
As you can see the AC card is inconsistent and it got close that time but N always stays consistent and faster than the AC shouldn't the AC be fast since its newer?
The router is a Motorola SBG6580
I'm testing both laptops from my room about a wall & 8 feet from router.
I know the router is not the best I have had trouble with it for a while now but my only frustration is that the older laptop is outperforming the networking capabilities of a newer computer.
Thats why I thought it would be because the older laptop has N and the router is for N.
Yes I have them both right next to each other facing the same place way.
I really like this laptop it has some nice features and it wasn't that expensive.
Do you know what form factor the Inter Wireless AC - 7265 is? Maybe a different card I can replace it with by a better manufacturer.
