[SOLVED] Wireless Adapter not recognised
Jun 3, 2020
16
I recently upgraded my wireless adapter from a geeric chinese one to an Intel AX200. I installed the card and the neccesary drivers, and it isnt recognised in Device Manager or Adaper Options. If its usefull, im running Windows 10 Pro 64bit and i using the Intel PROSET Wireless 21.90.3 driver. Any help?
Thanks,
PsychNet
Thanks,
PsychNet
AX200 is in laptop format (NGFF M.2/mini PCIe). Only a few adapters exist for desktops. Out of curiosity which is this? Laptop or Desktop?
In Device Manager > View tab is "Show hidden devices" checked?
In between wireless adapters did you use a wired adapter? If so be sure that that wired adapter is disabled.
I enabled 'show hidden devices' and it didn't show up, and i didnt use a wired adapter.
(Sorry if that sounded mallicious)
Reactions: wagner1618
