Wireless-g usb network adapter driver x64
thatmofo666
12
Hello,
im about to pull my hair out i have win7 x 64 and i can't find the driver that will work for a wusb54g ver.4 if i could get a link that would be awsome and not cisco because theirs does not work
my opinion is, if your router supports wireless N, then spend $10 on one of Newegg.com's daily shell shocker deals. If you're in another country, I'm sure that you can find one somewhere else also.
yes it is a pos linksys vista driver should work as long as its 64x because already found a few dozenof the 32 bit also a ralink i think its called but i can't find a legit download link anywhere
thats the problem all i can find is sys file's no .exe files to run it or i would the only things i have found is manual uploads and window does not reconize them as being compataible aka will not install
ive been to cisco i have that file it will not reconize it as a driver file it does not install and its not an true exe try it all it is an unzip file for the info i unzipped and tried to update manualy sorry for my terrible english.
watch it be a weird hardware problem which it shouldn't be because it is reconized. im going to smoke a cig i been f-ing with this thing for 2 days now being an advanced user myself. dude dont tear your hair out for this problem im bout to break it in a billion peices. let me know what you think
Can you think of any that can hook to and normal cable wire or a good cable booster brand with a fitting of a same size cable i got a land with a lotta ground to cover to get to my source. 10 acres sq
