wireless gaming mouse advice please
oAJAXo
38
Hi I've always been a console handset user when gaming. I'm going over to keyboard and mouse (ARMA 2/3 is calling). The problem I have is my PC display is my 47 inch TV (soon to be a 55inch 4k oled TV). My new keyboard is a g910 wired on an extension cable reaching 16ft. I need a gaming mouse. If wired it will need an extention cable going over the max limit of a USB cable. The other option is a wireless gaming mouse but thant will need to be at a distance of 6-7 feet away from the PC. I keep reading (and becoming very confused) about cycles, dpi, resolution, full speed device, low speed device, usb overclocking etc. etc. but my head is spinning. What I need is solution and recommendation (Palm Grip) for a Long cabled programable gaming mouse or a full speed over 6 ft wireless programable gaming mouse.
Can anyone help please?
Thanks. I'm looking to play FPS specifically ARMA 2/3. I have just e-mailed razerzone asking about effective distance from the reciever. (I sit about 6-7 feet away). I had to supply a S\N so just put 123 to bypass the field so I may not get a response. Looks nice, can you set the DPI to low for sniping?
AJ
Im not sure myself on functioning distance when wireless however it does come with a 7ft fibre cable. it has an on the fly dpi option so just click button to scroll between dpi options i have one of the older models and it goes between 800dpi and 5600 though i usually stick around 2100. it has an adjustable click pressure as well so when sniping you dont accidentally fire and you can also set it to an easier pressure for rapid firing.
