wireless intellimouse explorer
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Will a wireless intellimouse explorer work with win 98se
In news:E8AE9B7F-7F37-43A9-9521-5228FD077310@microsoft.com,
twb <twb@discussions.microsoft.com> had this to say:
My reply is at the bottom of your sent message:
Does not appear to:
http://www.microsoft.com/hardware/mouseandkeyboard/systemrequirements.aspx?pid=002
2k on up is what's listed as the requirements.
Galen
"You know that a conjurer gets no credit when once he has explained his
trick; and if I show you too much of my method of working, you will
come to the conclusion that I am a very ordinary individual after all."
Sherlock Holmes
It did two years ago when I last had a wireless mouse; however, as pointed
out by Galen, the ad now says W2K or higher. I don't have a wireless mouse
right now to try but I would not be surprised if it worked with W98SE
Regards
Ron Badour, MS MVP for W98
Tips: http://home.satx.rr.com/badour
Knowledge Base Info:
http://support.microsoft.com/default.aspx?pr=kbinfo
"twb" <twb@discussions.microsoft.com> wrote in message
news:E8AE9B7F-7F37-43A9-9521-5228FD077310@microsoft.com...
Thanks for the help, I will try it out
> Regards
In news:30E7F5E4-F6A4-4E6C-94DA-1EFACEFBE487@microsoft.com,
>> pointed out by Galen, the ad now says W2K or higher. I don't have a
>> wireless mouse right now to try but I would not be surprised if it
>> worked with W98SE
>> Regards
The last Intellimouse I bought was the wireless 2.0... I happen to have
recently done up a 98se box and if you really want I can test it on it. If
you already have the mouse then so be it, testing it on your own is as good
as I'd do. However, if you do not and want to know if it works before you
buy it then let me/us know and it's a simple matter of moving three feet and
wheeling the chair sideways. (Not difficult but I'm headed to bed inside of
2 minutes with any luck.)
Galen
Sherlock Holmes
Hi TWB,
I've been using a Microsoft IntelliPoint mouse V4.00.0657.0 for about 3 years now and it works just fine. Tend not to use the programme specific buttons though.
* * Pebble in Boulder * *
who would never underestimate the humble floppy
Microprocessor: Intel Pentium Ill 800MHz
RAM: 64MB
Video Memory: 8MB (VooDoo 3 2000)
Hard Disk: 20GB
Operating System: Windows '98 SE
OE v 5.50.4807.1700
IE v 5.50.4807.2300IC
"twb" <twb@discussions.microsoft.com> wrote in message news:E8AE9B7F-7F37-43A9-9521-5228FD077310@microsoft.com...
