Question Wireless Logitech G305 mice don’t work over USB hubs?
zillah
234
Hi folk
Recently my wireless mouse Logitech G305 stopped working and it was connected to Anker powered 7-port USB 3.0 Data Hub
https://www.anker.com/products/a7505
Tried to change USB port port on the desktop same issue
Tried to change port for the mouse transceiver same issue
I am using windows 10 it is up to date
I restarted PC twice it worked then it stopped
After that I connected the mouse transceiver directly to the Desktop's USB port same port as hub was connected to it and it is working fine
Thx
Well, there's no guarantee that it has to work through that USB hub. On the contrary, as said on the product description page you linked:
Additional Notes: Some USB 3. 0 devices require direction connection to host ports. 2. 4 Ghz wireless devices (keyboards, mice, etc. ) may not work around USB 3. 0 ports. Try using a USB 2. 0 connection.
For further issues, i suggest that you contact the manufacturer of said USB hub.
