Question Wireless Mouse no longer works
delpi767
12
Windows 10 - Asus 470 MB
The wireless mouse that I have used with this machine has stopped working
  1. This mouse works fine on other machines
  2. A wired mouse plugged into the same port works fine
The only change I've made is to install an NVME on a PCI card. The NVME works fine and the mouse worked previously with a different NVME installed on this card..
The mouse also does not work in the BIOS so it isn't a Windows problem.
Any thoughts?
Thanks
Logitech Mouse with dongle.
I have removed the PCIE card and the mouse still doesn't work, but works fine on another computer 3 feet away.
I have
replaced the batteries​
set the BIOS to default​
rebooted several times​
It is a UEFI Bios so the mouse should work in the BIOS.
Wired mouse works fine both in BIOS and with Windows
