Wireless Network Card for ASRock Z77 Extreme4 Motherboard
ncasolo
262
I just moved into a new house and I've not found any solution that will allow me to operate my PC in a wired mode. Since the reason I have the PC is for online gaming this is a bit of a letdown. I would like some advice on choosing a network card for my PC that is operating using the ASRock Z77 Extreme4 Motherboard.
I have an HIS IceQ Turbo 7950 video card installed that certainly takes up a lot of space (as far as I can remember nothing else is installed on the mobo). I've not opened up the side of the PC yet to see exactly what kind of space I have, but I've got to believe there's a slot I can use. However, if a USB device would work for me that's an alternative I'm open to.
Is there anything else I need to know about installing it other than plug-n-play and installing the device drivers? In the past I've had to disable the wired networking on a PC to get the wi-fi to come up.
If it helps I'm using AT&T U-Verse for my home internet connection.
Thanks in advance for your help.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166073
Rosewill RNX-N250PCe (RNWD-11005) Wireless Adapter IEEE 802.11b/g/n PCI Express 300/300Mbps Transfer/Receive Rate 2T2R 64-bit/128-bit WEP, TKIP, and AES WPA, WPA2
$17.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166074
Rosewill RNX-N250UBE (RNWD-11006) Wireless Adapter IEEE 802.11b/g/n USB 2.0 2T2R / 2x 5 dBi External Antenna / Up to 300Mbps Wireless Data Rates 64/128-bit WEP (Hex & ASCII), WPA/WPA2, WPA(TKIP with IEEE 802.1x)/WPA2(AES with IEEE 802.1x)
$19.99
I've not installed anything on them the only reason I wouldn't have access to either slot would be the size of the video card. I find it hard to believe though that both would be blocked. Thanks for the advice. I'm going to attempt a card rather than the USB option.
Any thoughts on this D-Link? I've got a $25 Amazon gift card and an Amazon Prime account for shipping.
http://www.amazon.com/D-Link-Systems-Wireless-Express-DWA-548/dp/B008L2PREI/ref=sr_1_6?ie=UTF8&qid=1375293985&sr=8-6&keywords=PCI+Express+x1+wireless+card
Installed the card. Started updating some software and couldn't break 100kb/s down (6mb service so I should pull ~600kb). Started chatting with tech support for my brand new ISP (I figured they had me setup on the wrong speed in their office) and after I restarted my router I was having massive connectivity problems. Turns out the card isn't labeled Roswill in my devices so I was really confused.
Eventually though after rebooting my PC after the gateway rebooted I was able to get connected. Signal strength seems good. As long as my connection is stable this will be perfect. Installation was a piece of cake. Thanks for your help.
