S sarahlou90 Honorable Jul 16, 2013 1 0 10,510 Jul 16, 2013 #1 wireless turned off on hi-greade d7000 how ca i turn it on ive almost everything
Solution Tradesman1 Jul 16, 2013 Try uninstalling the driver, then reboot, it should reinstall by itself, might also want to check the web site for an updated driver
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Jul 16, 2013 Solution #2 Try uninstalling the driver, then reboot, it should reinstall by itself, might also want to check the web site for an updated driver Upvote 0 Downvote Solution
