M Mufanky Reputable Dec 8, 2015 1 0 4,510 Dec 8, 2015 #1 I have upgraded from Windows 8 to 10 and now my wireless connection disconnects continuously. Is there a setting I need to change or an updated download needed? Thanks!
Solution Lutfij Dec 8, 2015 When you mention upgrade, did you go through these procedures How to Upgrade from Windows 8 to Windows 10 How to ditch the problematic Win10 upgrade and replace it with a clean install Disregard the above if they were performed to the dot and try these solutions: Having Connectivity Issues in Windows 10? Try These Fixes!
Lutfij Titan Moderator Oct 7, 2009 54,076 4,748 173,390 Dec 8, 2015 Solution #2 When you mention upgrade, did you go through these procedures How to Upgrade from Windows 8 to Windows 10 How to ditch the problematic Win10 upgrade and replace it with a clean install Disregard the above if they were performed to the dot and try these solutions: Having Connectivity Issues in Windows 10? Try These Fixes! Upvote 0 Downvote Solution
