I just bought a new pc case and the power button would not work upon further investigation I found 2 small wires that came loose from the plastic enclosure it was connected to. Do I heat the ends up with a soldering iron and jam them back in there or can this not be fixed?
Here are images so you can see what I'm talking about.
https://ibb.co/t2Wnf29
https://ibb.co/X3m2yBk
