Wiring 4 wire heat sink fan to charger
1cky
Help me out guys! I found a scrap Intel D34223-002 fan. 12vDC 0.60A I was wondering if I could rewire it to some laptop/psp charger looking thing that outputs 12v 1.5A. if yes, then how? the fan wires are black yellow blue and green. and the pins of the charger looks like THIS. will it explode? lol!
If no. why? my other option is to wire it to a 9v battery or 12v battery. but which wire should i use and which should i ignore?
please help me out guys! I'm planning to make a DIY room cooler to beat the 3rd world heat. THANKS!
(I have no idea where to post this.)
1cky
yes it helped me with the wiring, but is it safe to use the power supply/charger that i mentioned? if so, then will which wire should i attach to which pin?
Similar threads
