Witcher 3 FPS drops with 980 TI and i5 4670K.
CFSHeisenberg
Commendable
Aug 1, 2017
20
Hello!
I have the Asus strix 980 TI and an Intel i5 4670k.
Today i saw that in Witcher 3 in the cities my cpu usage sometimes rises to around 100% usage on all cores. At the same instance my fps drop to around 50 to 55 fps.
I am playing on 1080p with ultra settings and hairworks off.
I can not quite make out what the issue here is. I suppose my i5 is bottlenecking my card in this game, considering i should at least get a stable 60 fps on ultra settings.
This also happened in battlefield one today, where my cpu usage rose to a 100% and my FPS suffering from it.
Please, help me out.
EDIT: I forgot to mention that my gpu Usage is only at around 60% and the temperatures of my gpu are not exceeding 60 degrees Celsius. My CPU on the other hand gets temperatures of 70 degrees and upwards.
D
Your cpu is bottlenecking your 980ti in certain areas. Try turning down shadows and see if that helps. If you dropped a 4790k in you wont have this problem
