So I'm building a mini-itx general-purpose PC right now, and I'm trying to decide between Lian Li's PC-Q08 and PC-Q11 cases.
I'm not willing to consider mini-itx cases that require slim DVD writers, such as a lot of silverstone cases, because, well, slim DVD writers cost about 3 times as much.
I'm using an intel i5-760 quad core with a EVGA GTX-460 and a modular PSU.
The PC-Q11 is smaller by nearly 4500 cubic cm (about 3 Kleenex boxes in size). However, it's smaller size entails sup-par cooling.
So my question is this:
If I do not intend to overclock at all, how big an issue do you suppose cooling will be with the Q11?
I'm willing to spend $50 or less on third-party cooling solutions if needed.
I did find a cooling performance test here, but I wasn't sure what to conclude from it.
The performance test initially stated that
Thanks so much for your help!
but then they go on to sayThe Q11 cannot take a quad core CPU though. Even at stock speed and voltage, we found our i5-750 was hitting its thermal limit and throttling with Prime95.
Which seems to imply that it won't be too bad provided I find a better cooling solution.On a positive note, throughout the 3D test, the system remained completely stable and usable with either a Core i5-750 or i5-661 installed, meaning the case can still make a very small and portable gaming system.
