revolultrablue Distinguished Dec 18, 2010 253 0 18,790 Feb 24, 2015 #1 I have both the heat pipes of my gtx 970 and cpu cooler touching my side panel fans. I just noticed today and was wondering if that is safe to do. Any help would be greatly appreciated.
Solution Dark Lord of Tech Feb 24, 2015 I wouldn't leave it like that , will eventually cause issues.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Feb 24, 2015 Solution #2 I wouldn't leave it like that , will eventually cause issues. Upvote 0 Downvote Solution
revolultrablue Distinguished Dec 18, 2010 253 0 18,790 Feb 24, 2015 #3 What type of issues are you talking about? Any if that's an issue is there any way you can suggest some low profile 120mm side fans? Upvote 0 Downvote
revolultrablue Distinguished Dec 18, 2010 253 0 18,790 Feb 24, 2015 #4 It touches on the plastic of the fan. Upvote 0 Downvote
