My motherboard is Gigabyte B85-HD3 and suddenly pc wont startup.
so i checked psu by shorting two pin and it's worked fine
i also checked power switch and it's work perfectly.
what i did was short the PSU power on wires(green+black) when plugged to the motherboard and pc startup normally and i removed the two pin that i had short and after that pc worked fine
i did some restart and did some bios updates and tried turning on the pc and it all worked
the porblem is
if i disconnect the power line for 1 or 2 minutes i cannot turn on the PC again
i have to short the two pin to power up the pc...
what could be the problem.
mobo is out of warranty
the porblem is
