Hello
So, my workstation has 3 Windows OS on it. Each Windows is on a separate SSD. I have Windows 8.1 on 120 GB SSD Kingston, Windows 11 on 120 GB SSD Kingston and Windows 10 on 240 GB SSD SanDisk Plus.
My Spec are;
MBO: Asus Prime X570-Pro
CPU: Ryzen 9 5950X
RAM 64 GB Kingston Fury Beast DDR4
Cooling: Noctua NH-D15
GPU: 2x Asus RTX 3060 12 GB GDDR6
PSU: Seasonic Focus GX-750 Full Modular
HDD 4TB
HDD 160 GB
SSD 120 GB
SSD 120 GB
SSD 240 GB
5 screens attached AOC and Asus
Now, I had one workstation before with also 3 Windows systems on it Win7, Win 8.1, and Win 10 and I was switching between systems without any problems. Also each Windows system on its own SSD.
But with this new configuration, I have installed everything as I did on my old workstation and it worked for some time. But yesterday when I need to switch to Windows 8.1 and Windows 11 the blue screen showed "Recovery Your PC/Device needs to be repaired"....
The workstation boots without an issue to Windows 10 but when I select from the list Windows 11 or Windows 8.1 the error shows.
Also, one interesting thing is if I unplug 2 SSD the PC boots normally to Windows 8.1 or Windows 11. But when 3 of them are plugged in I can only boot to Windows 10.
I'm stuck here on what to do. This is my workstation and I'm the only one that is messing around with it, and nobody else is using it.
Link to my video problem
Thank you in advance
My Spec are;
CPU: Ryzen 9 5950X
HDD 4TB
HDD 160 GB
SSD 120 GB
SSD 120 GB
SSD 240 GB
