GA-EP45-DS3L Mobo
Q6600
8800GTS
Samsung 80GB HD
Seagate 250GB HD
Thermaltake SopranoRS case
Ultra Xconnect 500 (maybe 550) Watt Power Supply (got from friend) with really stiff power cables
It seems to work with the case open (don't want to jinx it).
Let me know if I forgot anything.
Do you think something is getting too hot?
I was also thinking about that.
Additional Info: I added a new motherboard, cpu, and PSU. I was playing a few games last night and my monitor went blank. Last night, I just kept my case open and it didn't happen again (didn't think much more about it at the time). Today I started up my computer with the case closed. I was playing a few games and the same thing happened again. I tried restarting and every time it got past the windows logo, my monitor would just go blank. I took out my video card, put it back in, reconfigured the cables a bit, and let it sit. I finally got in, turned my resolution way down, did a defrag, check disk for errors, and virus scan. All revealed nothing. When I put the side panel of my case back on, my screen eventually went blank. The cables were a bit loose when I checked (especially the HD cable). It is pretty tight inside the mid-tower and I thought my case was just knocking into the cables. I also thought that it could be the heat. Now, I'm running my computer without the side pannel and it seems to working fine (it's been running for a few hours fine and I can play Crysis on High with no issues). I would like to figure out the problem though, so that I can put my case side panel on.
