I mean, if you're limiting your frames - you're telling the GPU to not work as hard - which in turn, I think, would cause your GPU to not give out the same FPS it was, right?
I mean if my GPU was throwing out say, 25fps with no FRTC enabled, would it get worse if it was enabled to say, limit to 30?
Because now my GPU isn't pulling so much power and all that it did to put 25fps out - now with me limiting the raw power further, it should worsen the FPS output...
Right?
I'm hoping I'm wrong cause the inclusion of this feature wouldn't make sense otherwise.
Right?
