Question Would someone please recommend a surge protector/backup battery combo for my desktop pc?
Gatchaman
100
Hello! I have power outages bow and then during storms so I'm looking for a reliable surge protector/backup battery device that will protect from surges and obviously provide enough power to keep my desktop PC from shutting down during an outage.
I think 625 V will do it as I don't have a gaming computer. I'd rather have too much than too little voltage support.
Amazon.com (USA) is my usual go to for hardware. But I will order from another site if necessary. I almost bought one this morning but some guy posted that his fried during the first surge/battery backup event so I wanted to fish in a wider band of opinions for a quality product.
Thank you all in advance.
Two areas of concern: power outages and power surges.
For power outages you need a UPS with enough battery to provide time for a graceful system shutdown. Generally all that is needed is power enough for the computer and one main monitor. Speakers, second monitors, and so forth not really necessasry in most cases.
A UPS is not intended for continuing game play, working, etc.. Likely moot anyway if power is out.
Surge protection is measured in Joules. Each power hit will reduce the available protection. The reduction is cumulative: a few major hits, a lot of smaller hits, or some combination thereof. Sooner or later protection is no longer there.
Key is to determine the requirements. Most UPS manufacturer's provide some sort of guideling to size the UPS. Mainly how much wattage (VA) is required for x amount of time. Premise being that the end user is present to turn off the supported devices before the battery power is run down.
The guidelines often favor more expensive UPS units and the actual performance may be lab based (ideal circumstances) versus real world environmental factors.
UPS units can and do offer some amount of surge protection. How much varies with the unit and the actual amount of protection is likely overstated via one means or another.
Plus UPS's provide power to the served PSU using different methods: sine waves, simulated sine waves, square sine waves..... That can make a difference as to how well the everything actually works/performs when actually providing power. Some PSU's being affected by the wave form provided.
E.g.:
https://www.lifewire.com/pure-sine-...use it:,interference with modified sine waves.
I have two small UPS units. Just enough battery for a few minutes use to allow me time to do a normal shutdown. During bad weather, especially storms, I shutdown beforehand and unplug my systems. Doing that also reduces the possibility of damage due to power surges.
What to do:
1) Work out your power requirements if and when power is lost.
2) Read more about UPSs and surge protectors. From both manufacturers (biased) and reviewers (hopefully unbiased).
Hopefully you will be able to identify a UPS that will meet your requirements and budget.
There may be other ideas and suggestions in the meantime.
You have to know how the UPS vendors try to fool you. The number that matters most is watts. Most UPS use VA which is related to watts but they use it because the number is bigger.
You want to read the fine print and see what the watt number is. You want to choose this based on what you feel is the maximum power your computer will ever use. Note if you machine has say a 750 watt power supply does not mean it actually uses 750 watts. It will depend on your CPU and video card mostly.
In general if you think 625 watts is enough look at UPS that have 900-1000 va numbers. The watts are not the same on all brands of UPS for some VA number you need to read the specs
Reactions: Paperdoc
