Would this AC adapter work as a replacement for my hair clipper charger?
Daboa
66
I've lost the AC adapter for charging my hair clippers. Would this adapter from Amazon be a suitable replacement? Below are pictures of my clippers and a screenshot of the adapter I found on Amazon.
Does anybody have an answer? I would love to be able to charge my clippers without buying an entire new model. Thanks.
The output is correct based on what I can see of the ad and what is on the clipper. I would look closely at the conector (plug) to be sure it's the same. Even if not, if you have the bad one you could splice it on.
Can you not find the branded replacement for the clipper you have? Not critical, but typically easier that way for compatibility.
There are three things to look at to see if the AC adapter is compatible:
  • The output voltage (V) is the same as what device wants.
  • The output current (A) is the same or higher than what the device wants.
  • The polarity is the same. The polarity is the thing that looks lik (+)---(• ---(-)
