Hi everyone, I have a 1080 Ti that with a factory watercooled block. This Aorus has been great in my system. I only use Mayhem coolant which gets changed every 8 months. I did remove the front left sticker so the coolant would be seen. You will notice under the water block there is a small black triangle for the Aorus falcon eye. This is under the block inside which also means the block has never opened. I flushed the block with distilled water and you will need to either need to blitz it or you can take the block apart. I left the right sticker on so you the RGD LED would add the effect. I am only selling it because I have since installed a 2080 Ti in my system. It's an amazing card and I will take 450 shipped in USA. I do not have the original box but it will be packed securely.
