Hello guys!
I've just received an x5660 and put it in my x-58 sabertooth, replacing an x5650 that was a bit too hot for my taste.
Apparently while in bios it shows that the cache is recognized from L1 to L3 and all cores are active, when I open CPU-Z it shows only one core and 12 threads, and only detects L2 cache.
I've tried stress testing in OCCT but linpack only detects one core (Core0).
The X5650 that I replaced showed all info and was detected correctly by OCCT.
Regarding temps, only realtemp shows 6 cores while coretemp crashes. With the X5650 I've been using coretemp without issues.
Can you help me determine which could be the cause of the problem?
Thank you!!!
Specs:
X5660 - 4,3 Ghz (1.3v)
X58 Sabertooth (bios 1402)
Thank you!!!
Specs:
