Not in any noticable way.Also does the audio codec affect my headphone quality?
Correct. The only thing that really will is the memory XMP profile and your overclock. Or undervolt to make the CPU run cooler - up to you.Also will the two motherboards make any noticeable difference when it comes to render times & fps? Also assuming not.
In that list was matters to me is:Pictures tells you nothing , those boards may look similar but they are quite different
The pro has the following over the elite:
Better audio codec (ALC1220 vs ALC1200)
Better power delivery in terms of PWM (IR35201+IR3599 doublers instead of ISL69147 with ISL6617 doublers)
Better heatsinking (massively more fin area)
Dual BIOS
EC temp headers , you get 2x temperature sensor cables for remote monitoring (i.e. not on PCB) of things such as GPU air inlet temp
Extra fan headers
USB 3.1 gen 2 type C at rear panel
6 layer PCB for memory OCs above 4400MHz
If it is worth it to you go with the pro of not go with the elite
