Hi everyone,
I’ve run into an issue with my old X570 motherboard, which I’m trying to set up in a new case for resale after upgrading to an AM5 platform. However, the motherboard isn’t responding to the power button or the shorting of the power pins to turn on. Here’s a detailed breakdown of what I’ve tried:
Thanks in advance!
(Explanation assisted by ChatGPT to explain the issue better)
- Initial Symptoms:
- The motherboard’s LEDs light up, indicating it’s receiving power, but pressing the power button or shorting the power pins does nothing.
- Troubleshooting Steps Taken:
- Swapped the RAM for a known working kit from another PC.
- Tested with a known working PSU.
- Checked different power outlets to rule out electrical issues.
- Reseated the CPU.
- Removed all components and ran the motherboard on the box with only the speaker connected (no CPU, RAM, or GPU). No POST beeps or response at all.
- Verified the case power button works by testing it with another motherboard.
- Results:
- Despite LEDs being lit, the board doesn’t power on or beep in any configuration.
- Other Observations:
- I’ve since tested all other components (CPU, RAM, PSU) with a new motherboard, and everything works perfectly.
- This leads me to believe the X570 board is dead or has an unusual issue.
Thanks in advance!
