I would appreciate an opinion about the motherboard in a new high end build with:
-ryzen 9 7950x
-noctua nh-d15s chromax black
-64gb gskill neo rgb 6000 cl30
-rtx 4070 ti
-1tb samsung 990 pro ssd and 4tb wd black hdd
-corsair rm850x
-fractal design meshify 2 rgb
I had decided for the asus e-e gaming but not sure. there are also some cheaper mb that i have seen people suggest like the asus tuf gaming x670e-plus or asus prime x670e-pro.
Some extra thoughts about the cooler if i should go for an aio water cooler since i work with corona rendering.
And would like to know if 850 watt is enough for this build but also considering a future gpu upgrade? i checked by swapping the 4070 ti for the 4090 in pcpartpicker and showed a 772w estimated wattage.Thanks
-ryzen 9 7950x
-rtx 4070 ti
-corsair rm850x
