Xbox One Pro ex controller not working on PC
If it doesn't work on anything it sounds like you got a dud. My advice is to contact Amazon and send it back either for a replacement or one of the wireless ones that come with a receiver for Windows PCs. I had issues with the wired windows xbox 360 controller I had. The wire connector inside it broke from a bit too much back and forth. Similar to the way that many phone charging cords break except this was worse because it was inside the controller. I replaced it with a wireless version and it's great. Works even better now that I am on Windows 10!
I've tried all my ports, but they make no difference. My controller doesn't even light up if plugged in, and it does not work on an xbox 360.
