Hey guys,
I have a XFX R9 295x2 that is powered by a Corsair RM1000X power supply. Previously it was supplied by a EVGA Supernova G2. Now the card was marketed on amazon.com with a lifetime warranty which I did confirm with XFX in 2016 via a ticket but now they are refusing to accept the warranty stating that it does not come under the lifetime warranty category but only has a standard 2 year warranty.
Long story short, I have a card which was once a beast, lying idle in its box. I need help finding a place to get it repaired.
The card lights up, fans spin up, pumps work, BIOS is fine. Reflashed a new BIOS just to be sure but yet same result, no display. I came across a few threads where people disable the slave GPU and use the card with 1 GPU, but im not looking to do that. Any ideas/suggestions and help would be much appreciated. I have tested out the motherboard power supply and every other component to eliminate all probable causes.
Any repair shops that could fix the card are also welcome as suggestions if I can't figure out the fault with the card.
Thanks for your time guys
