XFX Radeon 6870 finally went out, need a recommendation for replacement
Primal_Mojo
29
So I built my entire system years ago before GW2 came out, and last weekend, my video card took a dump. Everything else is fine, and I don't have the funds to replace or upgrade anything else, I just need to replace my video card. Unfortunately, as I'm sure y'all know, they don't sell the XFX Radeon 6870 DD anymore, but after 4+ years, I should be able to find something as good or better for a decent price, shouldn't I? This is what I had, and it worked great.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521#close
Could anyone recommend a comparable card that would work as good or better for as little as possible out of pocket? I just need something that will plug right in and pick up where my old trusty XFX 6870 left off.
Thanks! 😀
I hope I can remember everything you need to know what fits my build, like I said, I built it years ago, and haven't needed to update anything, so I didn't worry much about it. In 4+ years though, lots has changed in the way of components! Let me know if you need more than this:
ASUS M4A88T-M MoBo
AMD Phenom II X4 960T 3.00 GHz Processor
8GB DDR3 RAM
Running Windows 10 64 bit OS
Not positive (can't get the power supply out of the tower to check the label), but I seem to recall it's a 400 or 450 watt Rosewill.
Keep in mind, I'm not a hardcore gamer, just lots of MMORPGs and internet usage, watching movies, videos, etc. I'm certainly not looking for top of the line with this build - it's older, and I know that. Budget is preferably under $100.
If there's any other info you need, let me know. Thanks!
Cool, that's the same one another tech from Newegg just recommended for me. Personally I don't know anything about PowerColor, so I'd prefer to go with XFX.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150736&cm_re=r7_360-_-14-150-736-_-Product
Maybe if I'm lucky, my local Best Buy will have it in stock.
