XFX Radeon R9 280X Width?
El Pelican
44
Silly question but i need to know the width of this particular card.
Is the XFX wider than the Sapphire 280x vapor x?
The sapphire vapor x is 4 inches wide, around 10cm wide, but im not to sure about the XFX.
Thanks
I take the measurements are like this?
1 Length
2 Width
3:Height
Width : 5.63 inches?
Sorry, i dont use the imperial system.
thanks
Thanks man, much clear now.
Cant believe the xfx is wider than the vapor x, if you see the photos might not look like that.
