Question xfx radeon rx 580 compatibility
Apr 14, 2020
Hello.. i want to buy the XFX RADEON RX 580 8gb but i have an old motherboard which is the MSI 760GM p23(FX)..will this card work good?or i will have problems with bios or black screens?
Your motherboard (like most motherboards) has a PCIe X16 slot which is required for a GPU like the RX 580.
The most important requirement is the PSU, which should provide power connectors and deliver enough power for the RX 580.
What's your PSU model?
Thank you very much for your answer..i have a corsair 550watt with 8pin connector for the graphic card which i think will be ok
That board apparently does not have UEFI support. Does the text in the BIOS look like the old DOS style text, or is it a graphical interface?
If an old DOS style, no RX and most R9 cards won't work.
If it's a GUI, then maybe. RX cards (and most R9 cards) don't support VESA mode 103, and thus likely won't work. My only experience running into this problem though was with an old Dell XPS 8300. I can't speak specifically to your particular motherboard, but I suspect it might be an issue.
hello and thank you for your answer..yes this i was afraid too but i contact msi and they told me that i won't have any problem with bios and the card will run normal
Reactions: King_V
This info is not correct at all. The only time you see that UEFI type issue is with some prebuilts from HP and Dell. R9 and RX cards have no issue on legacy Bioses. I ran an RX 480 on an AMD board older than the one he has with 0 issues.
Nvidia cards are the ones that often have issues with non UEFI BIOSes, and only some.
