XFX XTR 550W for overclocked gtx 970 and 4690k
AV3Nguyen
23
Hello, my system:
CPU: i5-4690k
Cooler: cooler master hyper 212+ with extra fan for push/pull
GPU: MSI gaming gtx 970
Mobo: ASRock Z97 Extreme4
RAM: 2x4gb g.skill sniper DDR3-1600
Storage: 1Tb HDD, 500gb sshd, 120gb ssd
Case fans: 3 120mm blue led
The PSU in question is an XFX XTR 550W 80+ gold. I plan to overclock both the CPU and GPU with voltage increases. Will my PSU cope? If not, what is a good alternative?
Thanks in advance!
D
understand that TDP does not stand for "Total Drawn Power"; it's THERMAL DESIGN POWER/POINT, it's a heatsink classification. NOT an indication of how much power your gpu will pull. For many gpus and cpus the TDP does come pretty close to indicating max power needed for the chip. but for many others (especially overclocked) chips it has no relationship to reality at all.
the gtx970 will draw up to 270-300W without an overclock from time to time despite it's 145W TDP. with an overclock it will draw a lot of power. My gtx970 can draw up to a constant 220W of power when under a serious overclock (with spikes up to 300W).
and we know an i5 or i7 seriously overclocked can draw up to 200W of power (probably a bit less... depends on the chip and overclock)
so i'd say 650W would be the min for your build when overclocking. if you plan to keep everything stock 500W would probably be the min i'd recommend using.
I do believe you are confusing system power draw with GPU power draw. At least unless you know something Anandtech, guru3d and bit-tech doesn't.
http://www.anandtech.com/show/8568/the-geforce-gtx-970-review-feat-evga/15
http://www.guru3d.com/articles-pages/nvidia-geforce-gtx-970-and-980-reference-review,7.html
http://www.bit-tech.net/hardware/graphics/2014/09/19/nvidia-geforce-gtx-970-review/11
You have tested your system both with and without the 970 with a load meter to prove it can draw 300 watts?
you aren't listening. I'm not talking about "average power draw under load"
I'm talking about max total power the card will draw at any one moment. The 960/970/980 series gpus all have massive power "spikes" (actually the 780/780ti did the same thing, only no where near as drastic) where they draw for moments a heck of a lot more power then they draw "most" of the rest of the time. Yes, the average draw of my system is right in line with those websites. (well accounting for my cpu and fans anyway) However if you poll the system power draw under strain every millisecond as opposed to every second or an average of every few seconds, you'll see some pretty significant spikes in power draw coming from the 970.
My own will draw up to around 270W for brief moments at stock, while spending the rest of the time hovering around 150W... when overclocked it will hover around 190W-220W power draw, with spikes up to 300W (or close enough, i think the highest i saw was roughly 293W)
I'm not besmirching the 970. I love this card. it's a great card. I'm just trying to give someone some good advice on a psu to purchase.
yet again. it does NOT suck as much as a hawaii. But it does for fractions of a second from time to time. And i'm not high. This is standard behavior for these cards.
It's fine. Not a single major review site has felt the need to go back and revise their power recommendations with any of the Maxwell based GPUs. That tells you there are no issues.
