XP and SATA Hard Error Problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Greetings, After 12 months of flawless operation and not a single BSOD.
I have encountered a problem with
Windows XP pro. During a network setup wizard procedure in XP pro the
system required a restart after the
network setup wizard finished, XP rebooted to "Unknown HARD ERROR" and
stopped. The error screen or BSOD reported,
KERNAL_DATA_INPAGE_ERROR
STOP: 0X0000007A (0XE1751274,0XC00000A3,0XBF88D953,0X12B1D860)
(WIN32K.SYS-ADDRESS BF88D953 BASE AT BF800000, DATESTAMP 3DB6D462)
The system
Asus P4S8X MOBO
WIN XP-PRO SP1
1G PC2700 RAM
2 SEAGATE 80G SATA DRIVES, RAID-0
1 Seagate 8G IDE drive
1 Samsung DVD player
1 Samsung CDRW 40-16-48
1 Sony-Floppy
The system will not boot to normal or any safe mode.
I have tried to use to repair console from xp disk, chkdsk reports no
problems, chkdsk-/p or /f or /r will not run
and hang after about 10 seconds, screen displays 0% complete after 6
hours.
I have spent days reading Knowledge base files and web sites that
identify similar problems, but no clear directions
for dealing with SATA RAID-0 repair procedures.
Thank You For Your Time And Consideration
Mike H.
If youre installing xp with multiple hds other than the RAID set,youre
going to get problems.Physically disconnect the IDE hds during the install,
reconnect them after.Do you have the BIOS set to enable RAID,is it set
at RAID being 1st priority at boot,disable any other device.Recovery wont run
on a RAID configured system,also the CHKDSK C: /F syntex doesnt work in
recovery,its either:CHKDSK C: and /p or /R. Also,when installing RAID,one
MUST install thru booting to xp cd,then press F6 to install drivers for
RAID,then
continue on for installation.6 hrs of running a utility in xp...If actions
arent
noticed after 5-10 min., end the process !!
> The system
> Asus P4S8X MOBO
> WIN XP-PRO SP1
> 1G PC2700 RAM
> 1 Sony-Floppy
> hours.
> Mike H.
http://www.microsoft.com/resources/documentation/Windows/XP/all/reskit/en-us/Default.asp?url=/resources/documentation/Windows/XP/all/reskit/en-us/prmd_stp_fvlq.asp
may help
"Michael E Hagerty" <mike_hagerty@Charter.net> wrote in message
news:41276A20.E591D742@Charter.net...
> The system
> Asus P4S8X MOBO
> WIN XP-PRO SP1
> 1G PC2700 RAM
> 1 Sony-Floppy
> hours.
> Mike H.
On Sat, 21 Aug 2004 08:28:32 -0700, Michael E Hagerty
>system required a restart after the network setup wizard
>Asus P4S8X MOBO, WIN XP-PRO SP1
>1G PC2700 RAM
>1 Seagate 8G IDE drive, 1 Samsung DVD player
>1 Samsung CDRW 40-16-48, 1 Sony-Floppy
Before doing that, check the rest of the hardware - RAM, fans,
motherboard caps (bulging or leaking?) etc. See
http://cquirke.mvps.org/pccrisis.htm and
http://cquirke.mvps.org/bthink.htm
Error Messages Are Your Friends
Ignore this poster as his advice will damage your computer.
Paul Cyr
The Debate Continues... www.xvsxp.com
Protect Yourself and Others in 6 Simple Steps...
http://davechalkconnected.ipbhost.com/index.php?showtopic=1802
"Andrew E." <eckrichco@msn.com> wrote in message
news:ECE1F322-F12E-4350-A5BC-3E182F90C604@microsoft.com...
> install,
> run
> RAID,one
> RAID,then
> arent
>> The system
>> Asus P4S8X MOBO
>> WIN XP-PRO SP1
>> 1G PC2700 RAM
>> 1 Sony-Floppy
>> hours.
>> Mike H.
> set,youre going to get problems.Physically disconnect the IDE hds
> during the install, reconnect them after.Do you have the BIOS set to
> wont run on a RAID configured system,also the CHKDSK C: /F syntex
> doesnt work in recovery,its either:CHKDSK C: and /p or /R.
> Also,when installing RAID,one MUST install thru booting to xp cd,then
> press F6 to install drivers for RAID,then
> actions arent
Please ignore any posts from Andrew the Eejit. It would appear that the
nurse forgot to give him is medication today.
My great-grandfather was born and raised in Elgin - did he eventually
lose his marbles?
> BSOD. I have encountered a problem with
> The system
> Asus P4S8X MOBO
> WIN XP-PRO SP1
> 1G PC2700 RAM
> 1 Sony-Floppy
> hours.
> Mike H.
http://aumha.org/win5/kbestop.htm
lose his marbles?
Thanks for the info, I guess I should have been more clear, I was not
installing an OS or creating a dual boot, The system had been up and
running for 12 months with no problems or BSOD's.
> > actions arent
> lose his marbles?
No I was not doing an install or upgrade, the system had been up and running for
12 months with no errors, problems or BSOD's
> Recovery wont run
> RAID,then
> arent
> > The system
> > Asus P4S8X MOBO
> > WIN XP-PRO SP1
> > 1G PC2700 RAM
> > 1 Sony-Floppy
> > hours.
> > Mike H.
