XP does not detect Sound device
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I reformatted my computer recently, but ever since my computer does not
recognize my speakers. When I go to "Sounds and Audio Device" in Control
Panel, it tells me "No Audio Device".
Prior to the reformat, my sound worked fine. What can I do?
> not recognize my speakers. When I go to "Sounds and Audio Device" in
> Control Panel, it tells me "No Audio Device".
What sound hardware do you have? If it is onboard, did you install your
motherboard drivers?
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
I am having similar problems with audio. I always used headphones with the mic/phone jacks- no problems.
Then when my altec lansing headphones needed to be replaced, I bought a set with a USB connection.
They have been working fine, but the wire is worn, so I decided to see if the old ones were any better until I could get out to buy a new set.
My pc no longer recognizes the "altec lansing headphones" I used to use.
When I go into "sounds" in control panel, it says "no audio device"
I went out and bought new sennheiser stereo headphones with a 3.5 mm jack. I am getting the same message "no audio device" when I go into sounds in the control panel.
If I hook my broken USB headphones back up, it is listed as the default device in sounds.
Any ideas what I need to do? I don't want to buy another set of USB headphones because the sound was not nearly as good as the other type.
I checked for microsoft updates and everything is ok.
