XP Pro to XP Pro networking probs
BGates2B
371
I have an unusal networking problem.
I have my main system that's been running XP Professional since November without even a hiccup. I have it hooked up to switch so I can use it as a file server for all the drivers and programs I keep on it for newer systems/system repairs.
In the past, I've had no trouble with networking W9x machines to it, but yesterday I tried another XP Pro machine, and I couldn't get it to network. I set an IP addy on the file server (machine 1) for 192.168.0.1/255.255.255.0. I then set the second machine to and addy 192.168.0.2/255.255.255.0. I cannot spot the other machine on the network. Also, as a side note, the second machine has an ethernet NIC and a USB PC to PC connection (yes, those dreaded MSI boards :tongue: ). I tried disabling that, bridging the network, etc, to no avail.
Any help is appreciated.
Thanks
<A HREF="http://www.anandtech.com/myanandtech.html?member=87962" target="_new">My Rigs </A>
can you ping each opther, can you ping localhost, can you ping yourself?
If they squeeze olives to get olive oil, how do they get baby oil?
I can ping myself, but I cannot ping the other IP addy.
Also, I made sure the firewall was off, so that's not it either.
ok, sounds rather like a cable/card problem, assuming all is setup right, are you using the usb thingy or the ehernet connection- should be a crossover cable if going from ethernet to ethernet without a hub, I dont have a clue about usb network connections- my strong opinoin is that usb is for gamnepads and cameras- NOT networks.
I'm using the ethernet card, not the USB thingy.
What's even odder is that on boot-up, I can see the NIC's activity light flashing on the other machine (the one already booted).
Weird
squeezy question: how both comp are plugged together?
<i>if <b>you know</b> <font color=white>you don't know<font color=black>, the way could be more easy ...
K, here's the setup
Computer 1:
Abit KT266A board with AXP 1800+, XP Pro, 3Com 3C905B NIC, blue regular CAT5 cable, IP 192.168.0.1/255.255.255.0 Firewall off
Computer 2:
MSI KT133A board with T-Bird 1200@1400, XP Pro, 3Com 3C905 NIC, blue regular CAT5 cable. IP of NIC 192.168.0.2/255.255.255.0 IP of USB PC-2-PC 192.168.0.3/255.255.255.0 (USB LAN disabled in device manager)
Switch:
Netgear 5 port 10/100 Switch FS-105
Using default XP drivers for both 3com cards.
hmm..., K? from next gen or ds9? is it a clue? ny is it another? 😱 ...
oh, yep, understood.
student vacancies may involve boredom which may involve kiddies gibberish or senselessness.
how annoying it is! :lol:
<i>*mdr* if <b>you know</b> <font color=white>you don't know<font color=black>, the way could be more easy ... *mdr*<P ID="edit"><FONT SIZE=-1><EM>Edited by Labdog on 05/30/02 05:41 AM.</EM></FONT></P>
oh, i see.
but have you tested the cables, you ok?
Gee, didn't think one simple letter could cause such outrage :tongue: . I was actually thinking more "valleyish", though I never been there.
*cough* *going into professional mode*
Firewall has been disabled on both PC's. There is no option on the MSI board to shut off the USB PC-2-PC connection.
Not only tried different cables, but also a different hub, still no luck. There has to be some hidden setting that I am overlooking, but I don't know what it is.
there was no outrage, just a j/k. :smile:
<i>note: but im not stup. Mr Mod.</i> :lol:
you are registered since 11/11/00 & you have "just" around 200 posts, weird?!?
"comcrap", i like it. :smile:
I aspire to being in the ranks with FatBurger, Crashman, BTVillarin, Labdog, svol, etc
But, without being an Meltie or a scramtron.
I review the pages constantly, I just don't post a lot.
You never heard the term Comcrap??? 😱
Never before has a name been so fitting for a manufacturer!!
I swear, they go out of their way to make sure their systems are hard to mod. For instance, my laptop has a LT winmodem built in. But, you can't run NT/W2K on it and use the appropriate LT driver because the modem gets it resources from the bios (or some sh*t like that) and it won't work. Plus, it's a 266 MMX chip (not PII) but on SisSandra, it's slower than a 166 on a TX board (Laptop uses the OptiFire chipset; are they still around?)
Even their iPaq's suck, they're having trouble with the 3835's now. Geesh
Finally solved the issue!!!
Turns out the hub/switch were grounding out. Not sure why it stopped the XP machines but not the 9x ones, but I unplugged the switch, then plugged it back in.
Wahoo, it works.
Thanks Labdog and all others that helped.
this is a great red nice day. i have helped a guy & that has worked! LoL
<i>if <b>you know</b> <font color=white>you don't know<font color=black>, the way could be more easy ...<P ID="edit"><FONT SIZE=-1><EM>Edited by Labdog on 06/02/02 05:59 PM.</EM></FONT></P>
maybe you can help the big green, he seems to be a little constipate. j/k.
