XP won’t let tribes 2 run
zappa
9
Archived from groups: alt.games.starsiege.tribes (More info?)
All,
I’ve upgraded from 98 to XP and now I can’t run my Tribes 2. Program says
that my program is out of date and that there are no updates available.
Can some one please give me directions to cure this problem?
TKS, Frank
G
Guest
Guest
"Zappa" <Zappa@nospam.net> wrote in message
news:n2b7e.4844$gJ1.1119@fe11.lga...
> All,
> I've upgraded from 98 to XP and now I can't run my Tribes 2. Program says
> TKS, Frank
i think this is in fact vivendi's fault.
go to your tribes 2 folder and find the tribes2.exe and append the command
line with -online
zappa
9
Thanks for your reply Adrian. Sorry but I don't know how to do what you
suggest. My command
line is C:\Dynamix\Tribes2\GameData\SierraUp.exe
Da**d XP. I upgraded to have faster reaction times. Now I think Tribes 2
can't be run on XP
Frank
"Adrian Ng" <spam.ng@btopenworld.com> wrote in message
news:d3jf7j$oae$1@titan.btinternet.com...
>> All,
>> says that my program is out of date and that there are no updates
>> available.
>> TKS, Frank
> line with -online
smeghead
596
On Wed, 13 Apr 2005 11:36:46 -0400, "Zappa" <Zappa@nospam.net> wrote:
>All,
>TKS, Frank
That's not an XP problem, that's a Vivendi Universal Games problem.
The Bastards.
--==< S m e g h e a d >==--
G
Guest
Guest
> suggest. My command
Alter that shortcut to point to the Tribes2 exe file, instead of
"SierraUp.exe", and add " -online" (minus quotes) after the exe.
> Da**d XP.
Personally, I say "What's XP?"
That's the oddest reason for upgrading an operating system.
> Now I think Tribes 2 can't be run on XP
Well, if you alter the shortcut as you've been told/shown, you'll get T2
running again.
"There's violence to be done."
R.L.U. #300033, running WM 0.80.1 under MDK9.1(and a half)
G
Guest
Guest
> suggest. My command
Okay, find the shortcut on your desktop or whereever, rightclick, go to
Properties, and then the "Shortcut" tab. In the line where you see that
C:\Dynamix\Tribes2\...etc, add -online to the end of it.
That should do it, if the -online thing works.
If it doesn't, try reinstalling it.
> can't be run on XP
Yes it can. It's not like you're the first person to upgrade to XP :)
G
Guest
Guest
Mr K <duffstuff@hotmail.com> wrote in news:425d6079$0$327
$cc9e4d1f@news.dial.pipex.com:
Hehe, yep. I upgrade to trade one set of bugs for a different, brand new
set of bugs.
Looks like Zappa got bitten by an old updater bug that will never be fixed.
(It gets the comparison wrong when comparing the current and available
versions on the web page to the currently installed version.)
I also add my username and password to the shortcut so I can skip the login
screen.
G
Guest
Guest
> set of bugs.
Hehe... I don't. :)
G
Guest
Guest
On Thu, 14 Apr 2005 04:00:30 -0500, Quixote wrote:
> Defense turret is good, its a small program, and it prevents cheats. No
> reason not to install it.
> Quixote
.... other than it can cause instabilities.
Well, more than usual anyway.
G
Guest
Guest
"Mr K" <duffstuff@hotmail.com> wrote in message
news:425e3494$0$323$cc9e4d1f@news.dial.pipex.com...
>> Quixote
Not for me. I could tell no difference with my setup, of course mileage
does vary....
Quixote
G
Guest
Guest
"Quixote" <quixote@writeme.com> wrote in news:115ti6dga8ja569
@corp.supernews.com:
> does vary....
Check out Rodent's .plan posted here:
http://dt.nope.org/
He explains some brain damage in T2 and his work in DT to fix it. It
doesn't make T2 more stable but it handles the UE better.
G
Guest
Guest
"Quixote" <quixote@writeme.com> wrote in message
news:115ti6dga8ja569@corp.supernews.com...
>>> Quixote
i had no problems either.
but of course, it might crash t2, but is that really such a bad thing?
G
Guest
Guest
It crashed as normal? ;)
> of course mileage does vary....
Yup. :)
user
Splendid
Dec 26, 2003
3,944
> Quixote
Okay, I'll get that, but for the already-installed T2. :)
> ^,,^< Miracle, a lifetime [LD], DkAngel
_______________________________________________________________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
<><><><><><><> The Worlds Uncensored News Source <><><><><><><><>
user
Splendid
Dec 26, 2003
3,944
Pfhhht, sneezing can crash T2..........
*POW!* Back to the desktop with no warning.
smeghead
596
On 15 Apr 2005 00:07:13 GMT, ">^,,^< Miracle" <miracle@spamcop.net>
Yeah, but between the Unhandled Exceptions... Sheer joy!
I liken it to my married life. Everythings great, everythings good.
Then there's that sudden shift in the mood. Unexplained and
unexpected.
What did I say? What did I do?
Female Unhandled Exception Error.
G
Guest
Guest
">^,,^< Miracle" <miracle@spamcop.net> wrote in
news:425f565a_4@galaxy.uncensored-news.com:
> And okay, I'll admit it: not only was getting used to XP easy, I
> actually see the advantages of it and LIKE it. (Don't have the big
> one, Troy!! LOL)
There are reasons to hate XP, but usability isn't one of them. ;)
I'm running 2k at home and XP Pro at the office, and figure one of these
days I'll buy a copy of XP Pro to upgrade the home machine, but the $200
price tag is a bit hard to swallow.
user
Splendid
Dec 26, 2003
3,944
>>> thing?
> unexpected.
ROFL
{{{{{HUGZ!}}}}}
>^,,^< Miracle
smeghead
596
On Fri, 15 Apr 2005 03:55:49 -0500, ScratchMonkey
>> one, Troy!! LOL)
You can get an OEM copy for $130-ish, but you have to buy a piece of
hardware. Which, for a true geek isn't like a compulsory activity, but
a bonus!
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=604631
ZipZoomFly is one of my very preferred online retailers. Everything is
free FedEx 2nd Day, and the prices aren't bloated to swallow the
shipping, either.
G
Guest
Guest
T2's actually enjoyable... still?
> unexpected.
So get out the fixing stick.
.... actually, forget I just said that.
smeghead
596
On Fri, 15 Apr 2005 23:59:51 +0100, Mr K <duffstuff@hotmail.com>
Yeah, actually. Though tarnished and aging, it's still fun. Even on a
pub.
>> unexpected.
Which is more important, the length or girth of the fixing stick?
user
Splendid
Dec 26, 2003
3,944
"ScratchMonkey" <scratchmonkey.blacklist@sewingwitch.com> wrote in message
news:Xns9639134D71AAAscratchmonkey@216.196.97.142...
>> one, Troy!! LOL)
The year XP debuted my hubby got it for me as a birthday
present. I only needed the upgrade, but it was still $100 then.
That turned out to be the WORST present I ever received.
Talk about reformat from hell. But since then, I've learned to
install upgrades on top of fresh installs to avoid troubles I don't
want to deal with. If I ever get around to reformatting my desktop,
I'll go ahead and upgrade both personal desktop pcs to XP.
But shoot, I hate to think of how many updates it would take
to get current. Ish.
Better Idea: Buy two new desktop systems. :D
> ^,,^< Miracle, a lifetime [LD], DkAngel, needing a loan......
user
Splendid
Dec 26, 2003
3,944
"Smeghead" <tribesfan@hotmail.com> wrote...
> a bonus!
> shipping, either.
Good stuff! One question, though- what is a "non-peripheral computer
hardware component"? Would a hard drive qualify?
user
Splendid
Dec 26, 2003
3,944
>> unexpected.
Nuh-uh. No way! That's the best grin I've had in days. :D
Similar threads
