Hey there,
Today I was playing a game I play pretty often (Planetside 2) and noticed that my frames were unusually low. Whereas I usually get 70-80fps, I was getting around 30-40fps. I started up CoreTemp, and saw that all my cores were at around 90 degrees celsius. I closed the game and the temperatures stayed this high. I wasn't entirely sure about how usual this was, so I ran a CineBench benchmark and it gave a far lower score than normal. I shut off my computer for a minute, turned it back on, and it failed to start, giving me an error message about too high temperatures. I opened the BiOS, and found that the pump RPM was N/A. I then opened up my case and felt the tubes of water, only to find that they were in-fact no longer carrying any water through, as there was a small pocket of air I could see that was not moving at the end of two tubes.
I've now fully unplugged my computer and moved it out to give it a closer look. I moved the tubes a little to see if there was anything loose, and the bubbles flew down the tube to somewhere else in the system. I then decided that I shouldn't mess around with it much more.
I got this computer in 2015-2016 from CyberPowerPC (a decision I now regret wholeheartedly). Around half a year after it came, the water cooler began filling with bubbles, so I went through the arduous process of repackaging the computer and sending it back to them. They fixed it, apparently, and it's worked mostly fine since.
Around 5 months ago, I noticed that there were again some bubbles in the cooler. It didn't seem to be posing much of a problem, so I wisely decided to leave it alone (kidding of course). However, to my surprise, in the span of just a few weeks, the bubbles vanished and I forgot about the whole thing.
Now it seems it's completely conked out. I doubt I have warranty anymore for the computer (and honestly I do not want to repackage the whole thing) so I'm considering what my options are. Is there any way that I can hope to fix the thing on my own? Is purchasing a replacement cooler and installing it a possibility? I've unscrewed the cooler from the motherboard(?) and here's a few pictures. I have no idea if this looks normal or not.
It should be noted that while I gave a valiant amateur attempt to clean out my computer about a year ago, I did not realize I could take off the back panel, and thus didn't know about all the dust on that final picture (or about the <Mod Edit> cord job).
Is this a lost cause? Any tips?
