. Performance is the same unless cache sizes differ. (of course, I'm not accounting for 2-way, 4-way, or 8-way capabilities)
-mpjesse
how much is max cache for an opteron , still 1MB like san diego? or more? and wat is 2-way,4-way or-8-way , im guessin u mean no. of CPU's but :? im a bit confused to be honest
For the 939, I believe max cache the 1xx can have is 2MB (1MB x 2 for dual cores). But since your using them for gaming.. that isn't going to matter, if memory serves.
The 2-way, 4-way, and 8-way, If I understand correctly, is if you use a Server MB that sockets 2 opty's. Depending on how many cores it has to corresponding cache, makes it 2-way, 4-way, or 8-way.
So.. Opty with 2 cores with 2MB cache x 2.. is 4way.
Opty with 1 core but socketed with another single, is 2 way.
I think..
Not sure about the quad or 8 way. Unless I'm taking it the wrong way.. :lol:
You are taking this slightly wrong, though its easy to see why. A dual core CPU is still 1 way. It actually refers to the physical number of chips that are intercommunicating on the board. Here os the breakdown:
Socket 939:
1xx series, single and dual core 1-way chips.
Socket 940:
2xx series, 2 way single and dual core chips that are designed to be used in a dual socket mobo for up to four cores.
8xx series, these can be used in either 4 socket (4-way), or 8 socket (8-way) boards for a total of up to 16 cores.
Opterons currently have a max of 2x1MB of cache (1MB for each core, not to be confused with 2MB shared cache total). The only other difference between them and normal A64s is that they are "top shelf". usually made of higher quality silicon, and therefore overclock better. You can get a cheaper Opteron that will outperform a stock $1025 FX-60 in some cases.
