As for RAM, if your using a C2D then 667 is fine, 800 if you want. DDR2 1000 is not really neccessary for anyone except for memory benchmarks (which are not what most people buy computers for anyway)...
I'd disagree, C2D at stock is well matched by DDR2 533, but its not uncommon for them to overclock to a 1600MHz FSB, at which point DDR2 800 is very very usefull. If you are going for a decent water loop then you would not go far wrong with DDR2-1066.
...but if you get 2gig or more its not going to improve your in game experience at all. Remember that windows XP only detects a max of 3.25 gig, so you will need vista (or maybe XP x64, anyone want to verify that?) to use 4gig or more....
More than 2 gig, not much difference. I can *maybe* see a use for 3 gig, but Windows (wether Vista or XP) cannot allocate more than 2gb to any one process. Even on XP x64 and Vista 64 bit edition,
Only 64 bit apps can use more than 2gb of RAM.. 3gb is kinda usefull for your IM clients etc in the background I suppose.
XP x64 can access more than 4gb, I think its 2 terabytes? The limit in XP 32bit is 4gb, but that means it has 4gb of address space, and certain addresses will be used up already by AGP Arpetures and the like, the amount you actually see with 4gb installed varies from system to system, but its normally in the region of 3.25-3.6gb
However, 2GB is a VAST improvement on 1GB. Maybe not so much in terms of FPS while ingame, but in general Windows performance and game loading times, the Swap File usage is
drastically reduced and the overall feel of the PC is much nicer. I speak from personal experience here, when I first built my new Rig I went from 2gb of DDR1-400 CL3 in single channel mode (KT600 chipset) to 1gb of DDR2-667 CL3 in single channel, and it was really painfull. I have now gone back to 2gb
...As for being cost-efficient, in a machine that you have such high requirements for, you cant really be cost efficient. Just dont buy useless things like DDR2 1000 like I said b4.
I agree with the first part of the statement, but DDR2-1000+ is definately NOT 'useless'. It is expensive, but for high end C2D overclocking its worth it imho. All the tests you see showing anything over DDR2-533 offering limited benefit with C2D are done with the FSB at stock, where the 1066MHz FSB is the bottleneck with DDR2-667 and higher in a Dual Channel setup.
My personal recommendation would be:
e6600 - Decent CPU, the first of the 4mb cache C2Ds, much better price/performance than the e6700 and e6800, excellent overclocker.
Asus P5W DH Deluxe - Great conroe overclocker, I've seen these things benched with a 2000MHz fsb! Its also a fully featured board, it has EVERYTHING you could ever wish for, and more.
2gb (2*1GB) Corsair or Crucial DDR2-667 CL3 or DDR2-800 CL4 - Corsair are great, Crucial are part of Micron, DDR2-667 CL3 is slightly shorter latencies in terms of nanoseconds than DDR2-800 CL4, meaning every DDR2-667 CL3 module should be ok at DDR2-800 CL4 timings. This gives you enough o/c headroom if you decide you need it.
x1900XTX 512mb - Great gfx card, the ATis perform much better in Oblivion than the nVidias, and I say that as a historic nVidia fan, and as someone that currently owns a 7900GT. The Asus P5W DH also supports Crossfire if you later decide to add a master card.
Scythe Ninja Plus or Scythe Mine cooler - Both great coolers, better than the Zalman 9500 I was using before my current water rig
Viewsonic 19" VP930 - Only 1280x1024 like most TFTs, and as a CRT fan I do like 1600x1200 at 19", but even I accept that TFTs are taking over now. Better monitor than most of the 2ms ones imho because of the lack of overshoot on the overdrive, less sparkling. Has excellent reviews
You say you dont use much HDD space, so a 150GB Raptor would be nice, and my other sugestion of two 7200.10 250GB SATA drives on a RAID 0 array would be kinda wasted as you'd never use the space. You could save money here if you liked, the Raptor is expensive for the size, and the only *real* advantage is in loading times and windows startup times, when you have 2gb+ RAM. With less RAM, the 10k drive means your page file is quicker, but who uses 1gb with a Raptor?
I wouldnt really bother with an X-Fi unless you want to do things other than games, (are you a musician?) the framerate improvement is small, especially on games that are GPU rather than CPU intensive such as Oblivion, and the SnR is pointlessly high unless you are spending a fortune on speakers. The Realtek HD audio on the P5W DH is plenty good enough for me, and I have an Audigy 2 Platinum sat in the cupboard
Thats my thoughts... Feel free to ignore me
