Wit
Witch is what bitlocker is supposed to protect from (if stolen)
Unfortunately enabling tpm + pin/key isn't fully straight forward
Bitlocker can use pre boot bitlocker if you change it to allow it (password on boot) witch this does protect you if pc/laptop is stolen (but no protection from hardware tampering)
if your using dedicated tpm (dTpm) if it's stolen you can get the bitlocker key because it isn't encrypted between the dedicated tpm chip and cpu (if you enable TPM pin or/and security key this removes the issue as the tpm won't unlock to send the bitlocker key until pin or/and security key is inserted)
if your using a cpu tpm (fTpm) you "should" still be protected even if the device is stolen (but still recommend pin/secure key to be enabled)
Microsoft is already aware of this type of attack
https://learn.microsoft.com/en-us/w...ity/data-protection/bitlocker/countermeasures
https://www.dell.com/support/kbdoc/en-uk/000142382/how-to-use-bitlocker-with-pin (other systems will be similar turning off fast boot or minimum > Thorough in the bios)
Recommend turning off fast boot in windows (under classic power options) as well
