Help!
Recently i changed my PSU then when i try to start up the computer I get a "No signal" on the monitor (both hdmi and dvi with both integrated and card), and a solid DRAM light for about 5 seconds. To be more specific on the startup, everything turns on and lights up, including the GFX card and it's fans (at least temporarily), but nothing happens.
I tried to remove some RAM sticks etc.. and the results are:
RAM in slot 1 only = Boot (No display)
RAM in slot 2 only = Boot (No display)
RAM in slot 3 only = Boot (No display)
RAM in slot 4 only = Boot and works perfectly
RAM in slot 1&2 only = Boot (No display)
RAM in slot 1&3 only = Boot (No display)
RAM in slot 1&4 only = Boot (No display)
RAM in slot 2&3 only = Boot (No display)
RAM in slot 2&4 only = Boot (No display)
RAM in slot 3&4 only = Boot (No display)
RAM in slot 1,2,3, and 4 = Boot (No display)
I tried to update to latest BIOS version btw and it still the same problem.
Any ideas?
Specs:
Motherboard: MSI Z170A GAMING PRO CARBON (MS-7A12)
CPU: Intel Core i7 6700K 4.00 Ghz
Memory: Corsair Vengeance LPX DDR4 2400 C14 4x4GB (16GB)
GPU: Nvidia GTX 1070 ROG Strix
Any ideas?
Specs:
