[SOLVED] Z390 aorus pro wifi gpu
Dec 28, 2018
I'm trying to put together a PC using an aorus pro wifi motherboard and my geforce gtx 1070 wont fit.. it says its compatible and looks like it should fit.. but it's not going into the slot. Also nothing is bent
It should fit just fine, unless you are installing it backwards.
Some GPU come with a plastic or rubber protecting the PCIe connector...make sure to remove it.
Check this video of the installation.
https://www.youtube.com/watch?v=EXLkRrUGqOo
