Hello guys,
I would like to ask something because I was reading the manual of the mobi and I got confused. .
My mobi has the following fan connectors:
CPU_FAN , SYS_FAN(1,2,3,4) , SYS_FAN5_PUMP , SYS_FAN6_PUMP and CPU_OPT.
First, the hydrocoolikg pump (of the Corsair H150i Pro) should be installed on CPU_FAN or SYS_FAN5_PUMP?
Also the 3 fans that the radiator has should go on SYS_FAN(1,2,3)?
If I put the pump ON SYS_FAN5_PUMP it wouldn't be a problem if CPU_FAN is empty?
Can you guide me on where to connect the 1 pump and 3 fans of the radiators on the fan connectors I wrote you that my Z490 Ultra has?
