Z77 driver issues - USB Controller Code 28
Groggles
Commendable
Aug 24, 2016
Hello everyone, I don't know if this is the right place.
Spec
CPU: i7-3770
RAM: 32GB Corsiar Vengeance DDR3
GPU: MSI GTX1070
OS: Windows 7 Ultimate x64
Mobo: Asus Sabretooth Z77
I have recently suffered a GPU death and used it as an excuse for a SSD upgrade with it
Context on the GPU death, the computer suffered a sudden reset then failed 10 times to reset,
Installing a fresh copy of windows allowed the computer to start with blue artefacts all over the screen
I have now installed a Fresh 1070 gpu and got the PC running I have encountered 2 problems however.
Problem 1:
My USB controller is reading a code 28
Issue: The drivers for this device are not installed. (Code 28)
I however have attempted to install the What i believe is the right drivers
"Intel(r)_usb_eXtensible_host_controller_driver.zip"
The dialogue boxes all tell me at the time that it has installed correctly, yet after the reset it still says code 28
Problem 2: there is no driver issue with this part however it doesn't seem to recognise that I have a storage HDD connected via SATA, I would suspect the SATA drivers however the CD and DVD drives I use both work
Thanks in advance for any help you can give
Download and isntall all your drivers from Asus's website
https://www.asus.com/us/Motherboards/SABERTOOTH_Z77/HelpDesk_Download/
its probably the ASmedia driver you're lacking for that usb issue
