Z9PE-D8 WS running Great For Two Years Now Hot!!!Cores
Cleanbest
Commendable
Aug 11, 2016
24
Hello,
My name is Larry (a novice computer builder). October of 2014 I built my first system. motherboard, Asus Z9PE-D8 WS. - 2 x Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6GHz 15MB L3. - 8 x ADATA XPG V2 8GB 240-Pin DDR3 SDRAM.DDR.- SAMSUNG 840 Pro Series MZ-7PD512BW 2.5" 512GB SATA.- Western Digital Red NAS Hard Drive WD20EFRX 2TB. - ASUS ROG STRIKER-GTX760-P-4GD5 G-SYNC Support GeForce. PSU CORSAIR | AX1200I 1200W RT power supply. Liquid cooled with two independent all in ones 1 x Cooler Master Eisberg 240L Prestige on processor one and 1 x Cooler Master Eisberg 120L Prestige on processor two. Built into a Cooler Master Cosmos II - Ultra Tower Computer Case with many fans. Running Windows 10 Pro 64 bit. Much to my surprise for my first build it ran beautifully! Great temps & performance everywhere. Then two days ago I noticed it running slow so I Ran Aida and found that core temps had skyrocketed. Nothing had been changed by me at all. Then I started getting colored lines & dots across the screen. Then Windows shut down with a final message, something to do with hardware failure. At that point it wouldn’t boot, no post beep, nothing. I have now striped it down to only the ssd, processor cooing, ram & graphics card. It will now boot again but still running as hot with the colored lines & dots across the screen. Any ideas??? Thank you, Larry
Note: I'm not a lawyer in the slightest.
Those warranty documents are often made in a way that unless it's absolutely clear it's their fault, they don't have to do anything. This is to protect themselves (especially in the US) against lawsuits.
It really depends, some companies are very strict and unpersonal, some companies will be fair. You have to try. Even though they have strict regulations for warranty, they might be wiling to help (as long as you are still within the warranty period).
There's no telling what they will do. As a consumer you have certain rights, but what warranty covers is basically up to the manufacturer. So I'd say contact CoolerMaster support, if you can include those pictures of the leakage you posted, be...
What temperatures are hot exactly? Everything or just the CPU?
Is the CPU fan running? Have you moved the PC or did it get bumped? Did you change something in the PC lately?
If it's just the CPU and the fan is working you should reseat the HSF (clean it, apply new thermal paste). Remove all overclocks (CPU, GPU, XMP, all of it).
If it's not just the CPU, your motherboard might be broken and overvolting certain components. The lines on the screen are weird because that implies a graphics card issue as well.
Thanks for trying to help! No I haven't changed or bumped it. I'm uploading some screen captures to a hosting site that I was able to get from AIDA64 temps & voltages etc. after I striped it down. As soon as they upload I'll post the links. Thanks again! That's what is so frustrating, it ran perfectly from the start and now two years later out of nowhere.
I'm on my phone now and I see the images.maybe they need moderator approval for other accounts to view. Please give it seems time I really appreciate any help is can get. If I have to tomorrow I'll hand type the info. Thanks again! Goodnight.
I see 'm now, must've taken some time to upload.
Oh dear. Those temperatures are quite high (though not enough to kill your CPU), the voltages look fine. GPU looks fine as well (as far as voltages and temperature goes), but obviously something's not right.
So, those temperatures of the CPU are that high at idle, meaning that when it's on full blast, it can get even hotter, which is dangerous (the PC will shut off to try to not damage anything if it does get that hot). But if it has been running that hot for a long time without you knowing, that could be very bad.
The temperature readouts COULD be false, though that's kind of rare, especially with Xeons.
I would advise to open up a sidepanel, and confirm that the CPU fan does spin when the PC is on. If it is, it's best to take off the fan and heatsink and apply new thermal paste (have you done that? It looks daunting but isn't that bad at all). Look up the "grain of rice" or "pea" method, and obviously clean the top of the CPU and the base of the heatsink first, with isopropyl alcohol (90% or higher). You can use paper towels (I always do) but be sure that no fibers / small pieces of paper remain on the surface. If you have one, use a microfiber cloth, that's the best option.
When you've installed everything again (don't forget to plug the CPU_FAN back in, I sometimes do, and it won't boot if it's not connected), take out all the RAM sticks and put them back in, sounds stupid, but sometimes if they're not seated 100% you can get weird issues.
Boot the PC and check your temperatures, if nothing has changed, it's probably the motherboard that is the culprit. Although it could be the CPU itself that is the problem, this is unlikely since it's 2 years old and CPUs are sturdier hardware than motherboards. If it is the motherboard, you would have to try your hardware on another one, it's the only way to check, which sucks, but I can't do anything about that...
I think by some miracle I caught it within a hour or so. I've been keeping it off other than to gather quick dsts..Everything still under warranty. Now to get them to honor thrm.something is making those cores hot. But not the cpu pakage. yet all the fans & pumps are working.
I just realized something, the sudden drop in temperature could mean the heatsink (do you have a CPU fan or a watercooled solution?) doesn't make solid contact with the CPU anymore. Metal fatigue could be an issue, although unlikely. If it has a stock cooler on there (one with those plastic pushpins), check if they're all still firmly in place. If you slightly jiggle or pull the CPU cooler, it shouldn't budge and be firmly attached to the motherboard.
Well it looks like I found the problem. As I was preparing to follow your advice and reapply the thermal compound I first noticed an oily stain in the case below the GPU board. So I reviewed the photos from yesterday and sure enough there it is. The entire reason that I chose an all-in-one liquid cooling product from a large reputable company like Cooler Master was to avoid these types of problems. See photos below:
https://www.areamaids.com/community-links/lawrence/Oil-like-fluid-in-case-2.jpg
God only knows how badly damaged the graphics card is, it has the cooling fluid throughout it as well. Again see photos below.
Or the motherboard, cpu's etc.
I wounder how they might be held accountable for their defective product that I think carries a 5 year warranty.
Well I'll be finishing the dismantling. I appreciate any advice. Thank you!
Thank you James! I will but first I'll research their warranty a bit. Usually my understanding is that the limited part of a warranty is to cover them from damages caused by their product.
Any Lawyers understand all of this:
Cooler Master Limited Warranty Policy
Warranty all (non-networking) products purchased from COOLER MASTER as free from defects in material and workmanship for normal use by the original purchaser for warranty period.
The Cooler Master Warranty would like to assure all of the users of Cooler Master Products to be free from any defects as a result of faulty manufacturing or faulty components under the following terms and conditions:
COOLER MASTER is not responsible for damage to or loss of any programs, data, or removable storage media. You are responsible for backing up any programs or data on removable storage media.
Except for the warranties set forth herein, COOLER MASTER disclaims all other warranties, expressed or implied or statutory, including but not limited to the implied warranties of merchantability or fitness for a particular purpose.
Any implied warranties that may be imposed by applicable law are limited to the terms of this limited warranty. In no event shall COOLER MASTER be liable for any incidental, special or consequential damages, including but not limited to loss of business, profits, data or use, whether in an action in contract or tort or based on a warranty, arising out of or in connection with the use or performance of the product, even if COOLER MASTER has been advised of the possibility of such damages.
You agree that repair, replacement or refund, as applicable, under the warranty services described herein is your sole and exclusive remedy with respect to any breach of the COOLER MASTER limited warranty set forth herein. if, despite the foregoing limitations, for any reason COOLER MASTER becomes liable to you for damages incurred by you in connection with this agreement, then, the liability of COOLER MASTER will be limited to the amount equal to the latest distributors price.
Some states or provinces/jurisdictions do not allow the exclusion or limitation of incidental or consequential damages for consumer products, and some states or provinces/jurisdictions do not allow limitations on how long an implied warranty lasts.
In such states or provinces/jurisdictions, the exclusions or limitations of this limited warranty may not apply to you.
This limited warranty gives you specific legal rights.
You may also have other rights that vary from state to state/jurisdiction to jurisdiction. You are advised to consult applicable state and provincial/local laws.
1. Warranty Length
All products from Cooler Master at least carry 1 year warranty from the date of purchase, with the exception of power supply units which carry a 2-5year warranty. If no proof of purchase can be presented upon request, Cooler Master cannot be held responsible for warranty service.
( If you have no receipt, will follow serial number for warranty check. )
2. Who Is Protected
The original customer purchasing the Cooler Master Product is covered under the Cooler Master Warranty Program.
3. What Is and Is Not Covered
It is important to note that our warranty is not an unconditional guarantee for the duration of the Program. Any replaced parts become the property of Cooler Master. The Program does not apply to the software component of a product or a product which has been damaged due to accident, misuse, abuse, improper installation, usage not in accordance with product specifications and instructions, natural or personal disaster, or unauthorized alterations, repairs or modifications.
The Program does not cover any events such as below:
Any damages unrelated to manufacturing defects.
Any unsuitable environment or use of the product in Cooler Master Opinion.
Any product which has been modified without official permission from Cooler Master, or on which the serial number or warranty sticker has been defaced, modified, or removed.
Damage, deterioration or malfunction resulting from:
Accident, abuse, misuse, neglect, fire, water, lightning, or other acts of nature, commercial or industrial use, unauthorized product modification or failure to follow instructions included with the product.
Third party products using Cooler Master Components will not be covered by warranty. See your vendor or the manufacturer for information about servicing.
Repair or attempted repair by anyone not authorized by Cooler Master, Inc.
Any shipment damages (claims must be made with the carrier).
Unauthorized repairs to a Cooler Master product will void the warranty offered by the Program. Cooler Master reserves the right to refuse to service any product which has been altered, modified or repaired by non- Cooler Master Service personnel.
Cooler Master does not warrant that this product will meet your requirements. It is your responsibility to determine the suitability of this product for your purpose.
Removal or installation charges.
You are responsible for the cost of shipping the product to Cooler Master. Cooler Master pays the cost of returning a product to you.
Cooler Master reserves the right to replace the product with a service product at their sole discretion at any time.
Product malfunction or damage resulting from liquids or moisture.
All accessories that malfunction due to physical damage such as: USB cables, extension cables, adapter cables, adapters, power cords, screws, retention brackets, ear cups, and all other similar accessories.
4. Local Law And Your Warranty
This warranty gives you specific legal rights. You may also have other rights granted under local law. These rights may vary.
5. Limitations Of Implied Warranties
There are no other oral or written warranties, expressed or implied, including but not limited to those of merchantability or fitness for a particular purpose. The duration of implied warranties is limited to the warranty length specified in Paragraph one.
6. To Obtain Technical Support
If you need help installing or troubleshooting a product please submit a technical support request form at here.
7. Exclusion of Damages (Disclaimer)
Cooler Master's sole obligation and liability under this Program is limited to the repair or replacement of a defective product at our option. Cooler Master shall not, in any event, be liable to the purchaser or any third party for any incidental or consequential damage, (including, but not limited to, damages resulting from interruption of service and loss of business), or liability in tort relating to this product or resulting from its use or possession.
8. For Warranty Service
Global warranty is not currently available.
In North America:
If your product needs repair or defects within the first 30 days after purchase, please return it to the merchant from whom you purchased the product with and enclose a description of the problem and a copy of your proof of purchase with the defective product. All replacement products have an extended 30 days of warranty after the item has been received by the customer. For any extended warranty services covered under the Program, please log onto our website to complete the RMA request form online. The request form will allow you to request for replacement parts. If you have any questions regarding the RMA process, please contact our RMA department at support@coolermaster.com. When returning product, please be sure to enclose a clear description of the problem and your proof of purchase with the defective product and return it as instructed by the Cooler Master RMA Department. Be sure to package the product securely (preferably in its original packaging) and ship it postpaid. Your dealer or Cooler Master will not be responsible for damage due to shipping. During the warranty period, your product will be repaired or replaced without charge, excluding shipping and handling.
Outside North America and Europe:
If your product needs to be returned within the warranty period, please do so through the retailer or distributor from whom you purchased the product.
In Europe:
Within the first 2 years after purchase, please return your product (or for power supplies installed within our enclosures, just the failed power supply) to your dealer or reseller for a replacement. If the product is still within warranty and you can no longer return it to your dealer, please contact Cooler Master Customer Support for assistance and instructions. Cooler Master will not accept returns without prior approval and an RMA number.
When returning product, please be sure to enclose a clear description of the problem and your proof of purchase with the defective product and return it as instructed by Cooler Master. Be sure to package the product securely (preferably in its original packaging) and ship it postpaid. Your dealer or Cooler Master will not be responsible for damage due to shipping. During the warranty period, your product will be repaired or replaced without charge, excluding shipping and handling.
9. Product Limited Warranty Period
There's no telling what they will do. As a consumer you have certain rights, but what warranty covers is basically up to the manufacturer. So I'd say contact CoolerMaster support, if you can include those pictures of the leakage you posted, be nice and wellspoken, and they might help you. Don't do anything before you asked them.
Also, did you build the PC yourself? If not, then contact the company you bought the PC from, because they might replace it if you're lucky...
Like dad always said "Who ever told you that life is fair". Well my time is worth more than spending hours, days & weeks arguing with Cooler Master. I put in a call to them about an hour ago and had to leave a voicemail. Will see if they call even call me back. Time to start planing my second build. Without Cooler Master components. What do you think the chances are that the processors are still okay? They hit temps of maybe 175 f. If so I need to find a motherboard for at least one Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6GHz. Thanks for all of the help, at least I know it wasn't something that I did wrong.
If I were you, I'd just buy decent HSF (aircoolers) and a new motherboard, the CPUs are probably fine. Take them out, clean them with isopropyl, they probably didn't get any liquid on them. If you want silence and good cooling and are prepared to spend a little bit (though not as much as those liquid coolers cost) just buy Noctua coolers. I myself have a NH-U14S, those are quite expensive but whisper silent (probably more silent than your watercoolers) and keep my 6700K more than cool enough, even with a 10% overclock. Those Xeons of yours run on a lower voltage, so they'll stay really cool, you can't overclock them so liquid cooling isn't a benefit at all. Really! Just go with air cooling.
80C (175F) isn't enough to kill those CPUs. Those temps could shorten the lifespan, but that would mean 24/7 operation in those temperatures for months, you caught it early. Again, CPUs are most likely absolutely fine.
As for the graphics card, clean the gold plated connectors with isopropyl, and leave it to dry, you might even want to take off the heatsink, inspect for any scorchmarks or liquid stains, and also clean those with isopropyl, but if you do take off the heatsink you need to reapply thermal paste (just use the same thermal paste that comes with a CPU cooler, you always get enough for multiple applications).
Most likely there are thermal pads under the heatsink of your GPU as well, those need to be in the right spots (over memory modules most likely), so take the heatsink off slowly and take pictures so you can easily spot where they need to go back to.
It could be that the GPU is broken, because the liquid that dripped on it could have shorted something out. If you find any scorchmarks, it's best to not use that card anymore in case it breaks your new motherboard. If it doesn't have any, and you've cleaned it well, it could be still fine... No real way to tell but try.
Thank you so much for all of your help!!! I should have signed up here much sooner. I see That you are listed as "CPU's Expert". Before building what I can now refer to as my old computer, I had never attempted to even repair a computer. So I am a beginner and have found a great deal of enjoyment learning about them. I have what I'm sure is a very beginner question, if you'd be so kind to answer. When shopping for my new motherboard for my "Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6GHz". Can I use socket "LGA 2011-3" or only "LGA 2011". Also will all socket "LGA 2011" except my "Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6GHz". Thank you again!!!
Only the socket that's listed, so only 2011, not 2011-3.
The CPU's expert thing is just that I have more than 10 times been marked as the solution, nothing more. Most of us are just regular people, some might be working in IT, some not. I don't.
And take it easy, nice and slow, it can be very frustrating if you are in a hurry, but just enjoy it, it's a lot of fun to build PCs!
Most of it is really simple, handle it with care, and you can't really break anything. If you have carpet and get ESD a lot, make sure to ground yourself (with a wriststrap or touching something conductive that is grounded) to release any static electricity, some computer parts can be damaged by ESD. I never ground myself, I just touch something that's grounded and work on the PC, but I don't have carpet or woolen sweaters 😉
Most of the stuff only goes in one way, so there's nothing to really mess up.
Couple of tips:
Obviously, read the manual of your motherboard on how to install the CPU, it's pretty easy if you know how.
Look up the "grain of rice" or "pea" method on youtube, lots of videos about it, to know how to apply thermal paste. That's the easiest and best method. It's not rocket science, a little bit too much paste isn't the end of the world, it might cost you 1C, not a big deal at all. No thermal paste, or a tiiiny amount is BAD though.
The most frustrating thing about building PCs is all the front-panel stuff and the little pins (for example the fan headers), read the manual of your motherboard on what goes where, and prepare by having enough lighting around you to read the tiny print on the motherboard.
I'm sure you can do it, it's really easy. I've done it probably around ten times now, building a PC from scratch, and I can do it in about an hour, and that's being chill about it. If I need to hurry I can do it in less time, it's just the first time there's a lot of reading and figuring out.
So as I shop I’m learning that this is truly a total loss. A replacement Z9PE-D8 WS at best is now available only from questionable sources. If I take a chance on one of them it might only be to discover that my two Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6GHz were/are damaged. Finding myself chasing a never-ending loss. I’m sure that my ADATA XPG V2 8GB 240-Pin DDR3 SDRAM.DDR is antiquated as well. My first built has taught me to avoid liquid cooling at all costs. I’m not a gaming over clocker, I only even considered liquid cooling due to heatsink space constraints. I even have two new ARCTIC Freezer i30 Extreme CPU Cooler - Intel, 320W Ultimate Cooling Power, Direct-Touch Heatpipes that I bought but didn’t have clearance with the RAM. I think that this calls for a complete rethink. I believe that I have some very versatile, expensive components that are still usable. One Cooler Master Cosmos II - Ultra Tower Computer Case. One Corsair AX1200I power supply. One Samsung 840 Pro Series 2.5" 512GB SATA drive. Four brand new Western Digital Red NAS Hard Drives SATA 6 Gb/s 64MB Cache 2TB each. I was just getting ready to setup a RAID 5 when the Cooler Master Eisberg 120L Prestige destroyed my system. I would like to make use of as many of my salvaged components in my new build. I need a very versatile workstation. I run my 21-year business with this computer. Bookkeeping, Video editing & production, work crew scheduling, photo/graphical work, website design & maintenance fast and many sata, usb headers. No gaming. Nothing I see on the market is near as nice as the Z9PE-D8 WS unless I give up on the LGA2011 socket and upgrade to the LGA2011-v3.
Well, you might do a lot of video editing, which would warrant the dual CPU setup, but you could (if you have to buy new hardware anyway) just buy a new motherboard with single CPU, but if you want it set up as a true workstation you might really like 2 CPUs. It's up to you basically.
I did a quick search, I can get that motherboard from a lot of sources (although some didn't have it in stock, but could order it), butt that's the EU, so I did a quick google search with the word "buy" in it, Amazon.com currently has 18 of them in stock from 625$.
I myself have a Noctua NH-U14S, I can't tell you if it will fit with the 2 CPU setup, but it does clear the RAM, especially with low profile RAM (I have Vengeance LPX sticks), so as long as it's not too wide (don't think so, but I'd have to guess from images, so not sure) you will be fine with low profile sticks...
It really depends, don't know how much dough you have (to spend or in general), but seeing how much hardware might still be fine it's a waste to buy a completely new rig...
To start with, anyone that is considering Cooler Master components in their builds. Cooler Master customer service has not even returned my phone call of private message on Facebook.
Inventory:
Usable components list, the cost including tax & shipping of damage vs the cost of replacement or equivalent.
1 x Cooler Master Cosmos II - Ultra Tower Computer Case. = Cost $299.99.
1 x Corair AXi series AX1200i Digital. = Cost $336.98.
1 x SAMSUNG 840 Pro Series 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD) MZ-7PD512BW. = Cost $369.99.
3 x WD Red 2TB NAS Hard Disk Drive - 5400 RPM Class SATA 6Gb/s 64MB Cache 3.5 Inch. = Cost $273.97
1x LG Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal 12X Blu-ray Combo Drive. = Cost $129.95.
2 x NZXT IU01 USB Expansion Board. = Cost $39.98.
1 x NZXT APERTURE M 5.25 Bay Multi-Media Mesh Style Card Reader w. Dual USB 3.0. = Cost $34.99.
1 x VANTEC 4-Port SuperSpeed USB 3.0 PCIe Host Card w/ Internal 20-Pin Connector Model UGT-PC345. = Cost $24.99.
Total good reusable components cost = $1,510.84
Questionable components list, the cost including tax & shipping of damage vs the cost of replacement or equivalent.
1 x Cooler Master Eisberg 240L Prestige – High Performance All-In-One CPU Liquid Water Cooling System with 240mm Copper Radiator. = $179.99. Replacement cost. = $179.99. Would never consider liquid again.
2 x Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6 GHz 15MB L3 Cache LGA 2011 80W BX80635E52630V2 Server Processor. Cost. = $1,203.00 – Replacement cost. = $1,280.72. If replacement necessary would upgrade to LGA 2011-v3 to increase options for new motherboard selection.
4 x ADATA XPG V2 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600W8G9-DMV. Cost $639.96. Replacement cost. = 8 x Samsung “low profile” DDR3-1866 16GB/2Gx72 ECC/REG CL13 Samsung Chip Server Memory = $680.32
Total questionable components replacement cost = $2,780.99
Unusable components list, the cost including tax & shipping of damage vs the cost of replacement or equivalent.
1 x ASUS Z9PE-D8 WS Dual LGA 2011 Intel C602 SATA 6Gb motherboard. = Cost $537.49. Replacement cost. = $652.00 (Ships via Amazon from “Russian Federation” maybe not Asus vendor without warranty).
1 x Cooler Master Eisberg 120L Prestige – High Performance Push-Pull CPU Liquid Water Cooling System with 120mm Copper Radiator. = Cost $122.49. Replacement cost. = $ Would never consider liquid again.
1 x ASUS ROG STRIKER-GTX760-P-4GD5 G-SYNC Support GeForce GTX 760 4GB 256-Bit GDDR5 PCI Express 3.0 HDCP Ready SLI Support Video Card. = Cost $322.98. (no longer available equivalent) 1 x ASUS GeForce GTX 970 STRIX-GTX970-DC2OC-4GD5 4GB 256-Bit GDDR5 PCI Express 3.0 HDCP Ready SLI Support G-SYNC Support Video Card. Equivalent Replacement cost. = $264.99
Total Unusable components replacement cost = $1,039.49
Cost of repairing the system with original or equivalent components, now air cooled using new low profile ram provided that the questionable components “2 x Intel Xeon E5-2630 v2 Ivy Bridge-EP 2.6 GHz 15MB L3 Cache LGA 2011 80W BX80635E52630V2 server processors are still good:
1 x ASUS Z9PE-D8 WS Dual LGA 2011 Intel C602 SATA 6Gb motherboard. = $652.00
Total = $1,595.31
