Zalman Z11 Atx Mid Case & Graphics Card
spikekitten
30
Hey guys,
Im curious if i can fit a Zotac Geforce AMP Extreme Edition 6gb into my case (Zalman Z11 plus mid tower) before i buy it, i can remove the HDD cage if needed.
Thanks
Hard to say without having the case for myself, i am looking at the specs of both the components, the case it self is 260mm(W) x 498mm(H) x 525mm(D) and the gpu is 328mm long. So what you could do is to ruler or a tape measure to check if you can fit it.
hmm measured, without taking the hdd cage out it is 300mm long, taking out part of the cage to allow the card room would be 460mm roughly then again i could be wrong :)..what do you think mate, should i go with another card or?
thanks for the reply btw
