zoo tycoon 2 not enough memory?help!
scottyd
hi, im am trying to play zoo tycoon and when i went to start it up it said "you need 256 MB of system memory to run zoo tycoon 2 (192 megabytes detected)". Is there anything i can do? any help would be greatly appreciated.
thanks
Go to the start panel and type in system, go to system configuration and then hit the boot tab, then click advanced options, check the box that says maximum memory and type in 2046, click apply and ok on all of the windows. Start the game and it should work. Once your done playing repeat the process, but in maximum memory just uncheck the box. Repeat every time you play, its annoying but it works I had the same thing happen to me. This is for windows vista by the way if your using xp its probably something of the same the locations are just in different places.
Hi! I would like to thank you for the solution because it WORKS on my vista. I have been looking around trying to solve the problem but all I got were people telling me to get new RAM... but I have 4GB already. Thanks again for your knowledge :)
